In the future it would be great if the modes could determine spotlight activation by creating a rule. Currently I have only seen the ability in device setting to turn on/off the light. Within a mode a user can create a rule for the light to be active or not. Also since there is an ability to record on camera 1 when camera 2 detects motion for an option to keep light on or off.
As of now if Camera 1 detects motion I have it set to also record on camera 2 but the light goes on wish i can have it set to off. Again there are times that I would like or need the light and other times I do not need the light.
Yes I can always buy more cameras and have them setup with the light feature permanently off or camera with out but that isn't practical.
It would be good to be able to set a schedule for the spotlight activation. Adding it to the rule is one option - though maybe it should be an independent schedule? Rules and Modes are pretty complicated already.
Accessing Local Storage
