  • 1727 Views
ArloLagsBad
I have 4 pro 2 cameras and a base station. I want to add a 5th camera to my existing setup. Can I buy 1 Ultra? Can I combine them? If I do will it mess with my free plan? Do I have to change my base station?
The Ultra cams will only sync to an Ultra hub so you need to by a system. You can sync the rest of the cameras to the Ultra hub if you want or keep them as they are and use the Ultra by itself.
ArloLagsBad
Thank you for the answer! Are the plans different between ultra and pro 2? I heard two things so I’m not sure.
Yes, they are different. I think there's an FAQ here that explains this. The older cameras use the same old plans as before. Ultra needs a plan in the first place to record to the cloud - otherwise it's recordeed only to the SD card.
  • 1728 Views
