  • 7 Replies
  • 1995 Views
Cloudbr34k
Hi I'm just looking to understand why the battery icons are different when both are plugged in via USB cable.
7 REPLIES 7
Dannybear
Are the icons different between the arlo portal and the arlo app?
Or that two cameras have different icon types showing when plugged into the charger?
It would be helpful if you posted a screenshot, so we can see what icons you are seeing.
Cloudbr34k
Cloudbr34k
Sorry here is a screenshot. I couldnt upload through the app..
The top icon means the battery is fully charged; the bottom one means it is charging.
Cloudbr34k
Thanks for this, but both cameras are 100%..
ShayneS
What does the web portal or another device display? Do you have the latest version of the mobile app 3.6.6 installed?
