Arlo ultra now shows 2K instead of live 4K on local network? Ultra 2 still shows 4K.
After the latest update app update. Arlo ultra now shows live 2K instead of live 4K on my local network. The Arlo ultra 2 shows 4K. What's up with that
What plan do you have?
@Sam3490 wrote:
I don't need to have a plan to have 4K on my local network.
Yes, but if you have a plan for the camera it is useful to know what it is. This behavior is expected if the camera is in a secure plan (but not secure plus or no plan).
@Sam3490 wrote:
Would you l like to explain to me why this is expected.
I'm not saying it is desirable. Just that it works that way.
Are you saying that you do have a secure plan for the Ultra camera (not secure plus)?
@Johnny290 wrote:
Explain how it works that way since when
I don't work for Arlo, and I don't know why they chose to do this.
But this has been discussed here before - for example here: https://community.arlo.com/t5/Arlo-Ultra/Cannot-live-stream-in-4k-Anyone-else-having-the-same-issue/... There are several other threads on this issue.
The puzzle in your case is why you are getting 4K on the Ultra 2 (assuming it also is under the secure subscription).
Accessing Local Storage
