Arlo ultra not recording
Uknuta713,
You must have a subscription plan for Ultra recordings to be saved to the cloud.
Take a look here for more information: What are the available Arlo subscription plans and how much cloud recording is available?
If you've installed a brand new never before used kit, it does include 1 year free of Arlo Smart Premier.
Is the kit brand new? Have you installed it in the same country in which it was originally purchased?
Uknuta713,
If you're eligible for the free plan, it will automatically be applied to your account upon claiming the SmartHub.
The included free 1 year of premier allows for 30 days of cloud recordings.
How do I claim the smart hub?
Uknuta713,
"Claiming" the SmartHub happens when you set up your Arlo account and add the SmartHub.
You've already done this if you have cameras synced and they appear in the app. If you did not receive the free plan automatically, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I am having the same issue. My cameras just stop recording on their own. They don't sense motion and library disappears.
I talked to tech support twice. The only temporary fix for now is restatrting the smarthub. Apparently the engineers are working on a fix. This is on top of the other issues.
MVN
My issue was with the free 1 year subscription disappearing from my account.
Good luck with your issue
Accessing Local Storage
