  • 5 Replies
  • 3146 Views
KGSRETIRED
Is anyone else having a problem getting the magnetic mount to fit tight against the surface? I screwed in the spacer with the screw snug and the mount was loose.
KGSRETIRED
I finally got one to work. The big flat part of the white spacer goes away from the surface and not up against it.I  guess that was the problem .
5 REPLIES 5
KGSRETIRED,
It sounds like you may need to tighten the screw. You should hear a "snap" when sliding the plastic stopper into place. Take a look here for instructions on this: How do I mount my Arlo Ultra camera using the magnetic wall mount?
DamianR
Spacer is right way up ?
Needs to be with the wide end up under the screw head.
KGSRETIRED
Ok thanks I'll try it again
zincyellowcobra
Luminary
Luminary
I have the same problem. I’m hugely disappointed in this cam, start to finish. The loose mounting is just icing at this point.
KGSRETIRED
  • 5 Replies
  • 3147 Views
