Re: Arlo ultra local recording access
- Email to a Friend
Now it just says library and only cloud recording’s are available. When I go to the storage settings on my hub I can clearly see that there has been space used in there for recording. But the only way to access is to remove the SD card and read with another device. What happened to the app access?
- Email to a Friend
Try these, one at a time:
- Reboot hub
- Reboot phone
-Reinstall app
- Email to a Friend
Just got off the phone with "expert tech" and they said the only way to view local recordings was to remove the card and view it on another device...
- Email to a Friend
Funny how this all falls in line with the batch of first customers that bought the systems and got upgraded service for a year free running out. Now we find out that in order to keep any cloud recordings we need to pay for additional service and pay even more for higher resolution service. Their solution record local BUT it's unusable as a remote view system so just pay us even though the service (for 7 days) has always been free.
- Email to a Friend
MLBinVA,
Direct Storage Access allows you to save your recordings to an attached storage device on the SmartHub and view them locally or remotely. For more information on how to set this up, take a look here: What is Direct Storage Access and how do I use it?
- Email to a Friend
Also why don’t I get notifications when a video is stored Only to the local SD card in hub?
- Email to a Friend
as I said. It was working. Now it’s not
Thx.
- Email to a Friend
L8RDave,
If you're experiencing an issue with Direct Storage Access after following the setup instructions in the article linked above, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
