Hi,
Can anyone tell me what is the size of the holes to use factory screws?
Thanks,
D.
Just smaller than the screw... 😉
Seriously though, do you mean for the screw alone, or the plastig plug insert for brickwork ?
Hello,
the plastic part on the wall.
I think that 5mm is just right.
Have a mive day!
D1132
Have a mive day!
D1132
Accessing Local Storage
