Arlo camera
  • 1 Reply
  • 4243 Views
Thmic86
Hi i have a Black arlo camera with battery inside with usb c port. But cant connect. Dont have the box did buy it from someone.
This code is under Qr code
A5JD217XA06E5
Can someone tell me what type this is
Are you certain it is a USB-C port, and not a microUSB?
Look for a VMC xxxx label - it might be on the back, or it might be on the rubber seal.  Either way it is hard to see.
  • 1 Reply
  • 4244 Views
