I have seen an issue with the Arlo Ultra solar chargers where in the morning when the light is low the camera will get a charge fault. The issue is it wont charge ever even in full sunlight until you remove the cable and reattach. When will we get a firmware update to fix this? Why not have it recheck 30 min later or something not disable charging completely?
Veluth,
How often are you seeing this occur? A charging fault error could indicate an issue with the connection between the camera and the charging cable, reconnect the cable, ensuring it is connecting properly and see if you still experience the same behavior.
Accessing Local Storage
