Arlo Ultra when internet doesn't work
  • 11 Replies
  • 6166 Views
  • 6 In Conversation
jengio77
I see that if my internet connection doesn't works for some minutes, in this time all new video are lost, both in cloud and in SD card. Is it normal? I talk about only internet issue, no power issue. Thanks.
11 REPLIES 11
I have tested the Pro/Pro2 systems  (by pulling off internet) and have found that the system record to the usb backup as long as the system has power... have no doubt the Ultra works the same way if a mem card is installed
jengio77
My SD card works, buy if I unplug the Ethernet cable on base station, I don't find new video in the Cloud and in the SD card. Is this by design?
michaelkenward
Sensei Sensei
Sensei
@jengio77 wrote:
....if I unplug the Ethernet cable on base station, I don't find new video in the Cloud ...
By doing that you have disabled your Arlo system.
New videos can't get to the cloud without an Internet connection. That's what the Ethernet cable is for.
I assume that you mean or on the SD card.
Just another user
jengio77
I mean that if there's some temporary issue with the internet connection (I unplug ethernet cable to simulate it), I would like to see the video on the SD card... or this is not possible?
That's what's supposed to happen. It's a backup for when the Internet connection is broken. Of course, right now you have to eject the card properly to view the videos.
jengio77
If I eject the card properly, in the SD card I find only the videos recorded when the internet connection works.
My test:
1) Unplug the ethernet cable on base station
2) Wait orange led
3) Make a movement on camera
4) Plug the ethernet cable on base station
5) Wait blue led
6) Secure eject of SD card
7) Reading SD card on PC I find only old videos
What's wrong?
jengio77,
Check here to make sure you've set up local storage correctly: How do I record 4K videos to a microSD card?
jengio77
JamesC,
I've set up local storage correctly, on my SD card I find all the videos recorded when internet works.
I'm unable to find on SD card the videos when internet doesn't work.
I simulate this issue unplug the ethernet cable on base station.
Ideas?
Dazler
Did you got it to work.
I just tested mine and I was able to find the two videos.
jengio77
Now It works. I think that the solution is to wait more time from step to another step. If the internet goes down, the base station takes long time to switch in "SD card" mode.
Dazler
That is strange as it should record to the base SD regardless as long as you selected to record to SD card.
To have the 4k videos.
  • 11 Replies
  • 6167 Views
  • 6 In Conversation
