Arlo Ultra system with one Arlo Pro2, the Pro 2 wont stay connected?
For some reason it is the only camera that will not stay connected and says: "This Arlo device is offline. Please make sure it is connected to the internet."
If I power cycle it then it works fine for a little while and goes back to saying this?
It can be a connection issue between the camera and hub, either strength or quality. Try bringing the camera closer to the hub to see if the same thing happens. If that helps, a different location for the camera and/or hub may help.
Accessing Local Storage
