  • 7 Replies
  • 2042 Views
walidk
Greeting
I have Arlo ultra purchased several months back , was working fine , currently I'm facing issue with the camera out focus ,the live streaming is showing blure not clear , I tried to :-
1- cleaning the lens , charging , reseting , I tried all the possibilities without luck
appreciate your help
7 REPLIES 7
walidk,
What does the signal strength indicator show for this camera? How far away from the SmartHub is the camera positioned?
Do you experience the same behavior on recordings and live streams?
walidk
thanks for your reply , the distance is very near only 10 feet , yes same issue facing while recording and live streaming
walidk,
Who is your ISP and what are your download/upload speeds?
walidk
I have excellent speed 150/40. .....I have my second Arlo ultra camera without any issues , also I have Arlo pro 2 without issue
only I have the problem with one camera Arlo ultra , and as I have mentioned earlier everything was fine.
im not sure if the camera lens has technical issue from inside the lens maybe ?
walidk,
If it's just one camera that has the issue, it could be specific to that camera. Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
walidk
no the issue is not resolved
Might be worth taking a snapshot from the web ui, and posting it here.
  • 7 Replies
  • 2043 Views
