Arlo Ultra not detecting motion (Animal)
I have a Arlo Ultra and Arlo video door bell on the front of my house (pictured below). I have been noticing that the Ultra is not catching animal motion (50 lb animal). This Ultra used to have motion detection outside of the zones but now isn't detecting things in the zone. I have reset it and ensured its updated. Very frustrating as it would seem the zones and motion is something Arlo can't get figured out across products.
Last night I had a coyote go across my driveway on the yellow line. The video door bell caught the motion but the Ultra did not. It would appear the animal detection isn't working like it should. I have also had a raccoon do a similar path and not have the ultra pick it up. I have all the setting selected for all movement. This camera also seems to go through batteries much faster (from beginning didn't want to charge to 100%). Any one else see this going on with the motion vs the doorbell?
Drahthunter,
Try removing your activity zones entirely, save, and then rebuild the zones and test again. Do you see the same behavior?
I am suffering the same problem with Ultra and Ultra 2 cams, is there any update concerning this issue? Thanks a lot in advance.
Accessing Local Storage
