Arlo|Smart Home Security|Wireless HD Security Cameras|NETGEAR
Re: Arlo Ultra compatibility with Arlo Pro 2 & it's base
I bought the Ultra with the assumption that it would be compatible with the prior base stations.  The Ultra is my 8th Arlo camera--I'm VERY disappointed that my assumption was not correct.  There's nothing on the box that indicates the Ultra is not compatible.  BAD MOVE ARLO!
Message 51 of 87
Re: Arlo Ultra compatibility with Arlo Pro 2 & it's base as well as Arlo Pro
If you have a current subscription you can cancel it (and get a pro-rated refund) and when you add your ultra hub you will get the 1 year free subscription on your plan. No need to change emails to do it.
Message 52 of 87
Muddy168, SigSci
Arlo is working on introducing backwards compatibility to be released at a future update.
Message 53 of 87
Re: Will Arlo Ultra work with Arlo Pro
Thank you, seems kind of silly I can't add the updgraded camera to my existing system.
Message 54 of 87
Ultra is new. Ya gotta let the rest of the system catch up. Bugs to fix first.
Message 55 of 87
While the plan is for the old bases to support the Ultra, there is no plan for the old bases to support the key new features of the Ultra: 4k resolution, Auto Track and Zoom, local live streaming, and a simplified onboarding experience.
Considering that, there's little reason to want to add an Ultra to an old system.
Message 56 of 87
Can't add Arlo Ultra
Is anyone having trouble adding an Ultra to their base station?  I tried to follow the instructions on the pamphlet and in the video to use my Android phone app - won't work.  I tried to add it just like my Pro and Pro 2 cameras, but the only wirefree selection I have is for the Arlo, Arlo Pro and Arlo Pro 2 - won't work.  I went to the web and tried to add it there - aha!  There's a selection for the Ultra in wirefree cameras that does not appear in my Android app - but no base station is detected.  I tried to see if there is an app update available - nope.
Any suggestions?
Message 57 of 87
Re: Can't add Arlo Ultra
You really need the new "smart hub" Ultra basestation.  A future firmware will allow the Ultra to connect to an old Pro basestation, but you will need the new hub to support the key features of the Ultra: 4k resolution, Auto Track and Zoom, local live streaming, and a simplified onboarding experience.
Message 58 of 87
So this camera does not work without a smart hub?
Message 59 of 87
Thanks for the explanation, I'll just stick with my current system as it works fine and just get a motion light by the camera I wanted to replace with an Ultra.
Message 60 of 87
Does Arlo 2 or Arlo Ultra work with the Arlo Pro Base Station?
I have the Arlo Pro with 3 cameras and am looking forward to the new security system coming out that was showcased at CES.  My question is does anyone know if you can get add an Arlo Pro 2 or Arlo Ultra camera to work with the Arlo Pro base station or do you have to purchase a completely new base station making us stuck with the Arlo Pro cameras?
Thanks for the help
Message 61 of 87
Re: Does Arlo 2 or Arlo Ultra work with the Arlo Pro Base Station?
You're trying to read things into what's happening. The Ultar system is new and in flux. It's already been announced that a future firmware update for older bases will make them compatible with the Ultra cameras. The Ultra base is already compatible with the older cameras.
No one is stuck with anything but it may take a while to make everything work together.
Message 62 of 87
Not sure where does the "smart" comes from. It needs an Ultra hub.
My Arlo hardware: Q Plus, Pro 2, Security Light
Message 63 of 87
Arlo's name for it is the "Ultra SmartHub"
Message 64 of 87
Same here.  I did my research when pre-orders became available (CES).  Arlo was happy to tell everyone covering CES that they would be backwards compatible with the pro base stations.  I'd link articles, but prob frowned on here.  Just check out Cnets coverage of the ultra for example.  Have a pretty expensive paperweight that is sitting at the house today.  Not happy.
Nothing anywhere to this day on the fact that it is not compatible.  Argh!!
Message 65 of 87
This is perfectly acceptable if it was clearly communicated on the product page or box.  It is not.
Message 66 of 87
Highlighted
Not at all. There have been plenty of links to articles about Arlo stuff here. The competition is another matter.
A lot depends on what you understood by, and what those articles said about, compatibility.
The Utra and Pro systems are compatible. But at the moment you do need an Ultra hub to use Ultra cameras.
You can attach Pro 2 cameras to an Ultra hub. Maybe also other devices.
You cannot, yet, attach Ultra cameras to a Pro hub – that is said to be in the works – but why would anyone want to? It is the Ultra hub that provides many of the features that the Ultra cameras are supposed to deliver.
Message 67 of 87
This wAs advertised as backwards compatible on amazon.com. And now learning that it is not? Terrible Custer service
Model: VMC3030 | Arlo Wire-Free Camera
Message 68 of 87
I'd rather that Arlo fix the major issues and worry about backwards compatibility last. Give it time but, as has beens suggested elsewhere here, the advantages of using an Ultra base may be worth the switch from the older bases.
Message 69 of 87
To make this more than rumour, here is what it still says on Amazon.com:
Amazon.com : Arlo Technologies VMS5240-100NAS - 4K UHD Wire-Free Security 2 Camera System, White : C...
Is Ultra backwards compatible with my existing Arlo System?
Yes. Ultra can connect to an existing Arlo Base Station as well as existing outdoor security mounts. It is not backwards compatible with previous generation Arlo batteries.
Then again, the wording is less than crystal clear. It is for the two-camera system that comes with its own Ultra Hub. But it says the same thing for the standalone camera.
Message 70 of 87
"Considering that, there's little reason to want to add an Ultra to an old system."
Except for those of us who purchased new Pro2 cameras with its base less than a year ago and are now being asked to just throw that base aside and buy the new "Ultra" base. Arlo is getting alot of people angry here with their double-speak about compatibility. I'm done, frankly. I plan to sell this Pro2 system on CS and get an entirely new system that does not have "Arlo" on it. To everyone else, enjoy your frustration with this company.
Message 71 of 87
Two points, no one is asking anyone to "throw away" the old base. It has its advantages over the new ones. (Think alarm.)
Then there is the possibility that Ultra cameras will be compatible with the old hub when the official release happens.
That Arlo, and Best Buy, jumped the gun and put these things out three months early must be frustrating.
I wonder what Amazon knew that Best Buy didn't. Maybe its claims about compatibility will turn out to be correct. If not, there's a good chance that it will shout long and loud at Arlo.
Message 72 of 87
Will An Arlo Ultra Camera Work With The VMB3500 (base station)?
Will the sound feature work using an Arlo Ultra Camera with the VMB3500 (base station) ?
        Thank you ....
Model: VMC5040 | Arlo Ultra Add-On Camera
Message 73 of 87
Re: Will An Arlo Ultra Camera Work With The VMB3500 (base station)?
Don't believe th Ultra is compatable at this time to the 3500 base... maybe in future
Message 74 of 87
Arlo Ulta Camera
Will the Arlo UIltra camera work with my Arlo Pro system?
Model: VMB4500 | Arlo Pro/Pro2 Base Station
Message 75 of 87
