Arlo Ultra can't live stream and 0 second recordings
Just like many others on this site my Arlo Ultras will not livestream and record 0 second videos. I contacted support and their solution was basically, "sucks to be you, buy a new one."
I did something that has temporarily (maybe permanently) fixed my issue and I want you all to try it to and see if it works.
Log in to your router and disable the Arlo base station/smart hub from all wifi networks and only allow it to connect through a wired ethernet connection. After I did that I've had no issues. Sorry for not having more specific directions, but everyone's router is different. Usually there is an option for "Device manager" or "Attached devices". Hope it works!!
At one point I unplugged from my router and straight to the providers modem that doesn't have active wi-fi and it was much more stable. The one thing was that then I couldn't access the SD card because both the hub and phone must both be on the same wi-fi. So I'm curious if you can still access the SD with what you did.
When did this issue first occur for you? Your base station should only be connected by ethernet cable to your modem/router. You can find more info here: How do I connect my Arlo SmartHub or base station to the Internet?
I make the same recommendations to everyone I can, DO NOT BUY ARLO!
Unless you can tell me how to fix the massive audio and visual delays that the arlo ultras are well known for then I doubt it.
They're a complete waste of money as a security solution and until Arlo can figure out a near real time solution for them then I'll continue to warn people away from buying them.
Makes me wonder if anyone that works for Arlo, actually use the products they're supposedly meant to support as they'd very quickly realise their customers pain.
Has anyone found a solution to this? Yesterday my Arlo Ultra stopped being able to livestream or record more than 1 second of motion video after working fine for over a year. It just says, "connecting". I have 3 other cameras working fine.
You can start with rebooting the camera by removing and re-inserting the battery, or remove it from Settings > My Devices > re-add it.
like everyone else, I have had unplugged, rebooted, removed battery, logged in/out zillion times, unlinked/relinked every camera, reset base station, deleted all my apps and data, reinstalled everything......
Since this is affecting only 1 camera & you tried all TS steps I can provide you, your best option would be to contact support to further investigate what may be occurring with this camera. Arlo Tech Support
This was literally their response "I would suggest that you purchase a new one, you may check our online webstore at shop.arlo.com or you may also check out other retail stores." My Ultra is 14 months old.
I can see all your comments you posted in the past. Nothing was changed in the last several days. Don't know what you see that the mods deleted.
Accessing Local Storage
