  • 5 Replies
  • 1590 Views
Goublin
I have a Arlo pro base station with 3 pro3 cameras. I also have 2 ultra cameras which connect, but appear off line as soon as i click on live stream. I have tried all the trouble shooting, any help appreciated.
5 REPLIES 5
Try swapping the ultras with two of the Pro3s, and see if the problem stays with the cameras or the location.
Goublin
I have 3 pros already up and working perfectly. The ultras connect, but appear off line when i try to connect to live feed.
But did you swap camera positions? That could be a major clue.
Goublin
yes. The ultras work sometimes, sometimes they dont and appear offline.  They just seem to work sporadically which is frustrating
JessicaP
Hi Goublin,
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 5 Replies
  • 1591 Views
