One of my Arlo Ultra camera from the 4camera-base set always record video for just 1sec, after I tried to unlink the device twice, it still didn’t record for more than 1sec. And when I’m trying to connect the camera via my app, it never connects. Wanting to know what’s the issue with the camera. Attached is the video it records, only shows 0:00 to 0:00
The camera has always done this? Is this a new install?
Check the rule for the camera, and see how long it is set to record: https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Also, try swapping the camera with one in a different location, and see if the problem moves with the camera or stays with the location.
I tried swapping it to different locations, still the same result so I suspect it’s the camera having issue.
How can I get o fixed?
Try removing it from your account and then re-add it.
Tried multiple times, killing it and adding it back, didn't work. Still records the 1sec video whenever I use it...
Use the Contact Support link at the bottom here for a possible faulty camera.
Accessing Local Storage
