  • 4 Replies
  • 2019 Views
ECMT
all seems to work fine , but I do have two questions,
1- i am using now the Arlo App on my Iphone, but can i also downlaod the Appc for PC, and will i be able to select which one to use .
2- to run the App the iphone has to be connected to the same WiFi network as the camera.
does this mean that it is not possible to view the camera or to get motion messages when being away from home and connected to an other WiFi network
thanks
brh
@ECMT,
On your PC it will not be an app, but it will be a web page. I believe it is myarlo.com, (I came over  from Netgear so my login page is different from that). You can not log in to both at the same time, but you can decide which to use, (if you are using your mobile app, log in to the app. If you are using the PC then log in at the web page).
You can use either no matter where in the world you are, but for setup purposes, the mobile device and the devices must be on the same network.
Brian
On PC, here it's  https://arlo.netgear.com
But this will change soon as Arlo fully separates from Netgear, now they are two companies.
ECMT
Thank you very much for your fast reply ,
Regarding the switch from netgear to Arlo Ultra , I assume we will get a message when this will happen and in case this network link will also change, the new link.
So far all work fine , but still two more questions,
  • Color night vision, it looks that this is only possible when also the spotlight is activated
  • ZOOM function ; this is activated , but is not enough special when looking with a iPhon             Is there a possibility to stop the video at any time and to do a manual zooming for that particular picture . that would be very helpful for checking details
Side question, this for an other application,
What is the best camera with base for just having a picture when someone does appear on the front door , or entry port of a garden .   so just a detailed picture or video is needed showing the person appearing in front of the door.  Eventually with speaker option.   ( a doorbell itself is not needed, just the camera
Again thanks for the good support
ECMT,
To log in to your account on a PC, you can use my.arlo.com
1.) Arlo Ultra uses the spotlight for color night vision.
2.) It sounds like you might want to download the video and then manipulate it from there with a video player. Many users use VLC player to do this.
  • 4 Replies
  • 2020 Views
