I'm hoping someone may be able to post their experience around the vma5600.
I'd bought one and tested after receiving it. Plugged it into my floodlight and started getting a charge. Cool so it works. A few weeks later after finally getting some time to properly install it, I tested before mounting and it's no longer working. Tested on all my 3 ultras including the floodlight and I'm no longer seeing the charging icon on the app. Has something changed in the last 3-4 weeks in the background that may impact this?
Note the tests were run under full sun conditions.
It's got me stumped
Since it didn’t work on other cams, your prob right as to dud.
try Arlo support for warranty
What is the outdoor temps ??
The solar panel will not charge below 32F, not the panel but a safety built into camera to prevent battery damage.
( none of the cameras will charge below 32F )
check the contacts, make sure no crud got int there... I usu have to wiggle my a bit to start a charge if outdoors.
I'm ready to call it and say it's a dud. Quite disappointing actually...
Can am Arlo rep please contribute to this?
Current firmware version on the base station is 1.16.5.0_893_89fcc16
https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-SmartHub-VMB5000-1-16-5-0-893-89fcc16-16th...
JamesC, hoping you're reading this and can provide some insights
Edit: also found specific firmware releases for both Ultra and floodlight cameras mid January which still falls within the time period between tests
https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Ultra-VMC5040-1-070-51-1-241-87b6bae-17th-...
https://community.arlo.com/t5/Firmware-Release-Notes/Arlo-Pro-3-Floodlight-FB1001-1-070-19-3-26-39e2...
Accessing Local Storage
