My Arlo cameras drain rapidly after being plugged in the AC for more than 24hours resulting in the cameras going offline. How is this possible. Cant the Armo Ultras remain permanently connected a power outlet???
Generally, that can't happen if the camera is properly plugged in. When you connect power the battery icon should show a lightning bolt through it - do you see that? If not, there's a connection problem. If you do see that, it sounds like the power adapter is faulty.
I havent tried the other 2 cameras yet.
Ive had the problem before. Really annoying as I cant permanently plug it in.
Somehow this is a hardware problem. Swap at the store if possible or use the Contact Support link at the bottom here.
I havent tried the other ones yet.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
@RRRemco wrote:
Still not working. Camera drains when permenantly connected to a power source and then it goes offline.
Does the camera function when you remove the battery (of course connecting it to the power source)?
Hi @Litig8r187
How far are your cameras from the base station? I sound like they might be having a random signal drop or interference to the base station.
@Johnny290 wrote:
And now they want to start charging you for tech support.
Arlo doesn't charge for tech support. If someone tries to charge, then you are dealing with a scam support site.
https://kb.arlo.com/000062119/How-can-I-avoid-Arlo-support-scams
Hi John,
Thanks for being a valued Arlo customer. At Arlo, we value building trusted lifelong customer relationships by delivering an exceptional user experience.
We want to let you know that we’re making changes to Arlo Support, effective October 4, 2021.
What's changing?
We’ve added new Priority Support services to benefit Arlo users with service plans and users currently on an Arlo trial, including:
Priority agent assignment
Support handled by expert agents
Access to agent assisted support via chat and phone
If you do not have a service plan or trial, you'll still be able to access these services if your device is within warranty:*
Access to virtual assistant, Community, and self-help content
When your hardware warranty expires, you’ll continue to have access to Arlo’s virtual assistant, Community, and self-help content.
Next steps
If you need assistance with your device at any time, just navigate to Settings > Support in the Arlo App.
For Priority Support services, an Arlo service plan or trial will be required. To edit your service plan settings, log in to your Arlo account at
@Johnny290 wrote:
I guess you haven't gotten your latest email
Yes, just saw that email (but you had already replied).
Accessing Local Storage
