Arlo SmartHub cannot be discovered. Happened 3 weeks ago. Tried calling and saying to re-plug.
Hi guys,
I have been trying to connecting back my Arlo smarthub (cause of arlo camera kept going offline and tried to reset it), but I couldn’t discover it. This happen since 3 weeks ago, I had been talked to the support(the name: Andreas), but they just disconnected the chat with me.
They couldn’t fix my problem, only thing they keep saying is “unplug and plug in again”. Totally speechless!
I couldn’t call them cause of they closed.
Is there anyone have same problem with me? The smarthub light keep solid red (sometime going to blue for 1-2 minutes)
Also, I tried all the methods you guys mentioned (port forwarding, unplug the sd card and etc)
Any solution?
Thanks a lot
Likely it is actually amber: https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
That means the base can't connect to either your router or the Arlo cloud. Try a different LAN port on the router and a different ethernet cable.
You can also try resetting the base ( https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values ).
Who is your internet service provider?
I even press the reset button for 1 min, no response at all.
I’m using TPG by the way.
@Irismo wrote:
Well. I tried all the method including LAN port and new cable as well. It doesn’t work at all.
If the base was just purchased, then I'd exchange it with the seller.
Alternatively, try contacting Arlo support: https://www.arlo.com/en-us/support/contact.aspx
@Irismo wrote:
As I mentioned before, I contacted them and they just keep saying unplug and plug in again. It wasn’t helpful at all. At the end, I just disconnected my chat. This is ridiculous!
I was thinking you could insist on a warranty replacement. But as you found out, that could take a while.
Exchanging with the seller is faster, and it is quite possible that you have a defective base.
Accessing Local Storage
