Arlo Pro 5S Camera Battery Draining
  • 2 Replies
  • 801 Views
RGMaxwell1
I have a Pro 5S camera that is having problems with battery draining after I replaced a router on my home network. I have spent countless hours with tech support resetting the camera and then reconnecting my device to the system. I have two spare batteries that I keep charged on the charger and have been requiring to change the battery every 18-24 hours recently. Has anyone else had this problem?
"After I replaced a router" would seem to be a key item. WHat happens if you bring the camera closer to the router or swap it around with another camera (if you have one)?
RGMaxwell1
I swapped another camera and keep it plugged in directly to a power source. That seems to solve the problem...for now. Thanks!
  • 2 Replies
  • 802 Views
