Arlo Dual Battery Charger flashing yellow led
I just figured out why my dual battery charger would begin blinking yellow after a few mins of charging, and I would like to share the resolution and hopefully help save time for people experiencing this issue.
RESOLUTION: Place something (that has a little weight to it) on top of the batteries while charging. In my case, I used my multi tool. Apparently, the batteries shift upwards in the charger, losing contact with the charging pins in the dual charger. I hope this helps...
HNIC74,
Is there any debris in the recessed area where the battery should sit? You should not need to add any weight to the battery for it to maintain charging on the dock.
Accessing Local Storage
