App scheduling messed up since clock change
  • 4 Replies
  • 1572 Views
JoshBear
Hi
Strange problem today. The clocks changed in the Uk last night and the app scheduling is messed up. It is like the cameras time is out by an hour. When you look at the schedule the green bars on the graphs say the cameras turn off at 5.30am. (Before clock change it was 6.30am)
Then when you try and change the time of turn off back to 6.30 you click and but the time rotation dials already say 6.30am!
I am using an iPhone. Latest Arlo app and iOS 15. Any help appreciated.
Josh
JoshBear
Hi
yes.   Happy to report that it appears to have fixed itself.   Will check again tomorrow.  Maybe just needed 24 hours post the time change!
Josh
Try rebooting the hub. It may be that the firmware isn't up to date with UK time changes but the reboot may fix things.
JoshBear
Hi
thanks
Tried that but no change.  Still having the issue.
Josh
There are 4 time zones options for UTC+0 in the app.
Are you using the one that says Greenwich Mean Time?
JoshBear
Hi
Josh
  • 4 Replies
  • 1573 Views
