  • 1 Reply
  • 572 Views
margulies
I just upgraded all my cameras from pro and pro 2 to ultra,
all camers are set up, noticed battery icon with lightning bolt flashing on all cameras,
I also noticed none of the cameras are recording, only 1 sends me an alert on the phone but when I check, there is no recording and recordings are at zero, need some assistance,
also if there is other bugs in the system that anyone wants to throw out there it would be appreciated.
spent all day on this, put alot of thought into this upgrade, so far not thrilled with purchase.
Thank you!!
The lightning bolt battery icon shouldn't actually be flashing. If plugged into AC power or a solar panel the bolt should just be there. I haven't seen it flash so I wonder if there's a power issue.
It might be worth removing the cameras and resyncing to see if the problems go away. It's also possible that a complete system reset could be necessary to get proper operation.
  • 1 Reply
  • 573 Views
