  • 5 Replies
  • 1540 Views
Retired_Member
Not applicable
I have 5 cameras that store into the SD card, Ive chosen not to subscribe.
but everytime I open the app, i have to go through the subscriptions pop up and experience delays to access my recordings on the SD card.
very disappointed, the system was very expensive, response times are lack lustre so I thought itleast it would be nice to be able to use comfortably without a subscription.
is there anyway to remove this pop up?
next option is I sell the system and move to a brand that allows meets my needs.
thanks
5 REPLIES 5
JessicaP
Hi kwep,
Can you share a screenshot of which pop up ad you are referring to when you open the Arlo app?
Retired_Member
Not applicable
Hi Jessica,
screenshot attached.
it can take up to several minutes to access my SD card storage because of the “subscription “ ad, I also noticed that remote access to the SD card with port forwarding doesnt work either now the free trial is over.
thanks
That isn't linked to the subscription. Are you using an iPhone?  Or Android?
Also, have you reserved the base station IP address in your router?  If the base IP changes (which it can), the ports can end up forwarded to the wrong place.
Retired_Member
Not applicable
Using ipad & iphone.
have also checked port forwarding, changed port and reinstated with arlo app. Arlo app sais it works, it just doesnt.
it appears something to do with subscription ending, just like the ad blocking viewing sd card on local network for 5 minutes everytime i open it.
  • Have you made sure that the router is forwarding the port (both TCP and UDP) to the IP address of the base station?
  • Have you also checked the operation both when the iPhone/iPad is on the local network, and when it is not?
Again, I don't think so.  There have been a couple of recent reports saying that port forwarding is misbehaving on iOS systems - they seem to be linked to iOS 15, not the subscription status.  In the posts I've seen, it seemed to fail when on the local network, but worked when away from home.
If your home router supports openVPN, then one option is to switch to that.  The openVPN mobile client is free.
  • 5 Replies
  • 1541 Views
