  • 10 Replies
  • 1792 Views
Sith77
Hello, I have 4 Arlo Ultra Cameras 2 where always plugged in and they are the ones that still work. The other two don't work anymore at all, I have tried everithing
With Battery/Without
Changed Adapters
Changed Cables
Synced...
Nothing works, the Cameras are totally dead. No lights, no charging, no connection.
SN: 5GG3977LA0D57
SN: 5GG3977XA0CB8
10 REPLIES 10
Did you try swapping the batteries with the cameras that are working (that is missing from your list).
Sith77
No that I have not tried. I will do so... however, the cameras should work without the battery inside when they are plugged in, I tested that with the working ones. The blue light comes on right away when they are pluged in without the battery.
I agree that they should.  If something's wrong with the charging circuitry though, they might not (but still work with a fully charged battery).
You could also try a reset (holding down the sync button for around 15 seconds).
Sith77
I will have access to the working ones tomorrow and will do the tests with the battery...
For now holding down the reset button for 15 seconds did nothing.
Sith77
I have now tested with working Arlo Ultra (plugged in) batterie and charger.
I have found that the Battery on the Working Arlo Ultra was empty -> hence was not charging. The Arlo only worked because it's was plugged in. So using the 1% charged battery from the working Arlo in the ones that don't work did nothing. And using the same charger as the working Arlo also did not bring it to life.
I have now 4 Arlo Ultra Cameras
2 Are Working because there where and are always plugged in. Batteries on them are booth seam to be nearly dead fully charged = 1%.
2 Are completly dead and batterys are also dead.
Unfortunately the warrany on them is expired, so I probably have to trash them....very disapointing.
Btw: I also have 4 Arlo Pro 2 Cameras that work like a charm with no problems at all...
Are you charging them with Arlo cable(s) and charger(s)?
Sith77
I have two genuine cables/adapters and one set that is not from Arlo with longer cable. However only one camera the one that works with the 1% Battery was plugged in to the (not Arlo Adapter). And that camera still works.
Running the camera and charging the camera are two different things.
It might be worth trying a different charger.
PaullyDB33
Hi, I have the same exact issue with the same exact camera. My single camera went dead after less than one year. I'm wondering if you have found a solution? I've even purchased a new battery and that didn't work. I don't want to have to purchase a new replacement camera either.
If you purchased less than a year ago, then it is still under warranty.  So contact support (using the app), and get a warranty replacement.
  • 10 Replies
  • 1793 Views
