Re: Arlo Ultra - no notifications, no recordings but motion detection works
HazzMatt Apprentice
There is a fix being tested right now for the ultra cameras not recording on Motion. If all goes well, we will all be corrected soon. Good luck to us all.
bstone01 Aspirant
UPDATE: All Ultra cameras that aren't on CVR won't record. I'm so glad I spent $1,150 to upgrade only to experience continued firmware issues from Arlo/Netgear. The promise of tech that never works is beyond annoying.
SuperZwu Guide
@HazzMatt  - Thx for the beautiful message 🙂
Mjbeuke Apprentice
I can confirm this is happening and actively being tested! Hopeful for a fix here!
Model: VMS5240 | Arlo Ultra 2 Camera Kit
KWish Initiate
Discovered my ultras are not recording any events just before I went on holiday.My pro 2 cameras are working fine on the same system.Reported it to arlo and was told there are issues with this happening and gave me a case number.In a whole week away I have received not one communication from arlo about what is being done to rectify this serious problem.The whole week my house was left unprotected especially my cars.It seems they take your money and leave you to your own devices.Utterly unacceptable!
Model: VMC3030 | Arlo Wire-Free Camera
Guru TomMac Guru
Had Ultra stop too recently.... but are you alble to restart the base remotely... It fixed my issue.
Biskitboy Tutor
Well, I was super excited to get 3xUltra's and install them today just to find out that I'm also part of the failure to record motion club.
I've had 8 of the original Arlo's working since 2015 without much of an issue. Hopefully, this will be sorted out soon. I was hoping all the Ultra issues would have been sorted out by now, but it seems that isn't the case.
Mjbeuke Apprentice
Hang tight guys - I’ve had a beta firmware on my base and cameras for nearly 48 hours now in testing. All is working well - no more frozen/missed motion triggers. Also the sound is working fine as I have another thread open about glitchy sound in Live streaming on the Ultras. I think a fix is coming soon - looks like they’ve got it resolved!
Highlighted
n1976jmk Luminary
Luminary
Thanks Mjbeuke, what else can you tell us about the firmware?
Its working great no matter if you are at home or away?
Anything else you can think to mention?
Thanks!!!!!
LandJS Apprentice
In support of what a couple others have mentioned, yes testing has been going on and after the hub update I only had once that a camera didn't trigger.  Then a camera update went out for testing and have not had a single issue since (fingers crossed) I even believe them to be functioning a bit better at night.  I have been doing a walk around of my 6 cameras a couple times a day,  put a dog on a long leash out there a couple times around the house to check and driven to areas where cameras are set to record a few times and then watching the videoes to be sure.  Hopefully you will all have this soon.
HazzMatt Apprentice
I'm also a firmware tested and have had very similar results so far, including 1 camera that was still not motion recordings at first. Seems to be ok now. I have two separate Ultra systems testing the beta release. Good Luck to All. I hope we're all good soon.
Bucfan444 Initiate
 This is been an ongoing issue since the last firmware update which multiple users have reported and I have been keeping track of multiple threads in this forum. I too am extremely frustrated with the situation. Arlo is supposedly working on a firmware update to rectify this but I have been without recording capabilities for over three weeks at this point.  Reset in the base station correct the problem temporarily But even this fix only last one day. Unbelievable considering the cost of these Arlo systems
n1976jmk Luminary
Luminary
Thanks @LandJS so you have the testing hub and camera firmware too?  Wow, I wish I did but hopefully Arlo will approve it and release it soon to the public.
@Mjbeuke @LandJS please keep the feedback coming 🙂
KWish Initiate
This product was not ready to be sold.Too many glitches and all we are are product testers but we are paying top money and in the meantime it’s open season for burglars!
Mjbeuke Apprentice
Everything is working 100% for me - I have my wife added as an authorized user with her separate account and Geofencing is also working perfectly either when she or I are away it is properly setting my system to my home or away custom modes I have setup.
Cameras are recording on triggered events every time - night vision is kicking on at the point of recording (and not starting out dark for a few seconds then kicking on) and audio - both on recordings and on Live View on 4K resolution - is no longer choppy. 4K recordings to the MicroSD are also properly recording and showing up in full resolution.
Everything with the Ultras is working 100% for me! Seems like there’s other testers with the same results - it looks like Arlo has got it!
LandJS Apprentice
n1976jmk it is nice when it works and I just like doing it sometimes, I used to beta test some in the 80's and 90's and can tell you it can be a nightmare when it doesen't lol
n1976jmk Luminary
Luminary
LandsJS
and
mJBeuke,
Who got you guys added to the test firmware? PM me if you’d like!
Yes I beta tested throughout my years too.
Thanks guys!
Qia Aspirant
Anybody has idea went the “ motion detection “ issue going to be fixed???
is almost 2 months, and, a lot of Arlo ultra customers don’t have the cameras working “ properly “.
the cameras won’t record the motions to the library.
please we need to know, what happens??
Model: VMC5040 | Arlo Ultra Add-On Camera
Gramm Aspirant
Patiently waiting for updates on this issue. The same exact problem with both my base stations. Only the Ultras connected stop recording. The Pros are not affected.
JamesC Community Manager
The development team is working on a fix for this issue. I will provide an update as soon as I have more information on the fix.
Thank you, JamesC
This issue is resolved with the latest SmartHub firmware release. For more information on this firmware, take a look here: Arlo SmartHub VMB5000 - 1.12.3.2_134_185068d - 19th August 2019
Thank you,
