I've spent hours per day over the last week trying to figure out why some of my Arlo Ultra Cameras stopped recording on motion. I have two different Ultra systems on two different accounts in two different states and both systems have this problem. Symptoms are: Arlo app shows last activity hours ago on some cameras, when I know there was activity during this time that should have been recorded. No recordings in the library for those certain cameras either, no surprise there. I've spent hours resetting batteries in cameras, rebooting the base station and even factory reset the base station and then rebuilding my cameras from scratch. The problem re-appears and it isn't always a specific camera that stops recording. The problem moves to different cameras. I do have some cameras that have a weaker signal that the others, but it isn't the weakest camera that always goes to sleep. Sometimes the weaker one will stay working but the stronger cameras can also be the one that goes to sleep instead. The only way to "wake up the camera" seems to be to either remove and resync the camera or reboot the base station. Despite a short restoral period, the problem appears again. After hours with Arlo Chat, going through the painful processes they must ask you to do or try - nothing got fixed. I finally got escalated to Level 2 support. Finally I was informed that the Ultra Base station received a firmware update on July 29th -the "exact day" that my problems started. My fault for not checking the Arlo website for a list of recent updates - it was there, Arlo Ultra Base update on July 29th. Unfortunately, Arlo cannot revert to the previous firmware version. At present, they don't know what came out in that update that "broke things". Anyway, I hope this report helps others to avoid the painful amount of wasted time troubleshooting that I've spent. Oh, another thing - I also have Arlo Pro cameras at the same location and they all work fine, they don't have this problem. Last thing: I've seen many claim that the Arlo Ultra systems don't have the range to cameras that the Arlo Pro has/had. I also have seen this. An Arlo Level 2 technician told me today that is absolutely not possible or true. If the power and sensitivity isn't less, the antenna pattern must be different. The result -not as good of range. I hope this helps at least one person! Take care and Good Luck! Matt
UPDATE: All Ultra cameras that aren't on CVR won't record. I'm so glad I spent $1,150 to upgrade only to experience continued firmware issues from Arlo/Netgear. The promise of tech that never works is beyond annoying.
@HazzMatt - Thx for the beautiful message 🙂
Had Ultra stop too recently.... but are you alble to restart the base remotely... It fixed my issue.
Well, I was super excited to get 3xUltra's and install them today just to find out that I'm also part of the failure to record motion club.
I've had 8 of the original Arlo's working since 2015 without much of an issue. Hopefully, this will be sorted out soon. I was hoping all the Ultra issues would have been sorted out by now, but it seems that isn't the case.
Its working great no matter if you are at home or away?
Anything else you can think to mention?
Thanks!!!!!
In support of what a couple others have mentioned, yes testing has been going on and after the hub update I only had once that a camera didn't trigger. Then a camera update went out for testing and have not had a single issue since (fingers crossed) I even believe them to be functioning a bit better at night. I have been doing a walk around of my 6 cameras a couple times a day, put a dog on a long leash out there a couple times around the house to check and driven to areas where cameras are set to record a few times and then watching the videoes to be sure. Hopefully you will all have this soon.
This is been an ongoing issue since the last firmware update which multiple users have reported and I have been keeping track of multiple threads in this forum. I too am extremely frustrated with the situation. Arlo is supposedly working on a firmware update to rectify this but I have been without recording capabilities for over three weeks at this point. Reset in the base station correct the problem temporarily But even this fix only last one day. Unbelievable considering the cost of these Arlo systems
Cameras are recording on triggered events every time - night vision is kicking on at the point of recording (and not starting out dark for a few seconds then kicking on) and audio - both on recordings and on Live View on 4K resolution - is no longer choppy. 4K recordings to the MicroSD are also properly recording and showing up in full resolution.
Everything with the Ultras is working 100% for me! Seems like there’s other testers with the same results - it looks like Arlo has got it!
n1976jmk it is nice when it works and I just like doing it sometimes, I used to beta test some in the 80's and 90's and can tell you it can be a nightmare when it doesen't lol
and
mJBeuke,
Who got you guys added to the test firmware? PM me if you’d like!
Yes I beta tested throughout my years too.
Thanks guys!
Anybody has idea went the “ motion detection “ issue going to be fixed???
is almost 2 months, and, a lot of Arlo ultra customers don’t have the cameras working “ properly “.
the cameras won’t record the motions to the library.
please we need to know, what happens??
Patiently waiting for updates on this issue. The same exact problem with both my base stations. Only the Ultras connected stop recording. The Pros are not affected.
The development team is working on a fix for this issue. I will provide an update as soon as I have more information on the fix.
Thank you, JamesC
This issue is resolved with the latest SmartHub firmware release. For more information on this firmware, take a look here: Arlo SmartHub VMB5000 - 1.12.3.2_134_185068d - 19th August 2019
Thank you,
Accessing Local Storage
