Has anyone tried a 512 or 1TB card with confirmed success???
Just curious - I’ve just ordered a 2 pack of ultras to add to my other Arlo gear - and I want to get the largest SD card I can.... the Pro 2 base accepted a USB drive which goes up to 2TB and that was nice - and I’ll have 2 ultras and 5 pros on the SmartHub so I’ll need all the storage I can get!!!
Also - does anyone know when Arlo will update the firmware to allow for viewing of the video through the base/app without having to remove the drive?
I read somewhere that will eventually happen and hope it actually does!
I haven't heard of anyone using that large a card. I would question whether it's needed - I have a 128GB card that's been installed since March and still has ~82GB left with 2 Ultra cameras and 2 Pro cameras recording at best quality for 30-60 seconds. If you're in a high traffic area it might make sense but many installations just don't need that much saved data.
The app/firmware update is loosely scheduled for by the end of the year. I would think maybe late Q3 or early Q4.
My cameras, mounts, power cables, and skins are all coming in Sunday. Looking forward to trying out the Ultras!
I have.512gb work perfectly on ultra.However,the size is not the problem,battery drain is much bigger problem even i install the official solar panel for ultra.In a single day , my battery drain from 52 down to 30 % ,solar panel only charge roughly 10 % a day.Now,i have to limit the recording period only in the late night time.T_T.(normally , if you use all 4 cam in your house and set it to ARM ,for me, i use about 4 gb per day for recording.(I live in town ,2 of my cams are in the front of my house which have so many people moving around all day and night)
That's what zones and either Arlo Smart or AC power is for. Additionally, rotate the camera down to eliminate more of the busy parts of the view and concentrate on what's truly important. Post screenshots of the camera view for suggestion.
Accessing Local Storage
