2 Ultra Base Stations
  • 4 Replies
  • 8725 Views
  • 2 Likes
farmerbrown
Is it possible to have two Arlo Ultra base stations? I have three Ultra cameras and one camera is too far away from the base station to receive the signal. I’ve tried moving the base station around in the house in multiple locations but no matter where I move it there’s always 1 camera that doesn’t have a signal.
Also would this require separate accounts with separate subscriptions or could I combine them under one account? Are there any other considerations and downsides I should be aware of when adding a second base station?
Thanks!
farmerbrown,
You can have as many base stations/SmartHubs as needed on your account. You can add one to your existing account and sync cameras that are closer to it to improve signal strength.
The only thing you will want to consider when adding a second SmartHub is you will need to Arm and Disarm that SmartHub separately from your current one. Active and inactive modes are managed by the SmartHub so cameras synced to a second SmartHub will behave based on that SmartHubs active mode.
farmerbrown,
VCG
Do both arlo base stations need to be connected to ethernet.?
farmerbrown
Thank you James
VCG,
Yes, both base stations/SmartHubs will need an ethernet connection.
  • 4 Replies
  • 8725 Views
  • 2 Likes
