VMS-5500-100NAS base station
  • 6 Replies
  • 690 Views
Bosco381
Arlo base station VMS-5500-100NAS base station will not add Ultra cameras. It says I am not online, but this is wrong.
6 REPLIES 6
Being noted as offline has to be fixed first. What is the hub's LED showing? Did you successfully connect it to your account first? Are you using a VPN?
Bosco381
The VPN is turned off. The base station and computer are connected to the Netgear router with an Ethernet cable. I have added the cameras with an old VMB-4000 base station. They work fine but will not add to the newer base station listed above.
Bosco381
The hubs LED says it is connected , but when country to add Ultra cameras it says I am not connected to the internet.
What country are you in? I wonder if Ultras (and many other newer cameras) aren't supported in your region.
ponchi
Hola! I'm from argentina, the base station, don't work . I'm buy recently and never be used.. what can i do? It's online but un the app says offline
BrookeN
Which basestation are you referring to?
  • 6 Replies
  • 691 Views
