  • 4 Replies
  • 1019 Views
tecmcord
will the 5000 automatically recognize my existing pro 2's
Assuming you're installing the VMB5000 new, the answer is no. You'd have to remove each camera and sync it to the 5000. It's like starting new - because it is.
tecmcord
yes it's a new 5000 install. I have installed the new ultra cameras but it does find Pro 2 (H5) any idea's. They worked fine on the vmb3500 base station
tecmcord
doesn't fine the pro2's
@tecmcord wrote:
yes it's a new 5000 install. I have installed the new ultra cameras but it doesn't find Pro 2 (H5) any idea's. They worked fine on the vmb3500 base station
You might need to remove the cameras from the account and then re-add them.
  • 4 Replies
  • 1020 Views
