will the 5000 automatically recognize my existing pro 2's
  • 4 Replies
  • 1005 Views
tecmcord
Assuming you're installing the VMB5000 new, the answer is no. You'd have to remove each camera and sync it to the 5000. It's like starting new - because it is.
tecmcord
yes it's a new 5000 install. I have installed the new ultra cameras but it does find Pro 2 (H5) any idea's. They worked fine on the vmb3500 base station
tecmcord
doesn't fine the pro2's
@tecmcord wrote:
yes it's a new 5000 install. I have installed the new ultra cameras but it doesn't find Pro 2 (H5) any idea's. They worked fine on the vmb3500 base station
You might need to remove the cameras from the account and then re-add them.
  • 4 Replies
  • 1006 Views
