local recording issue was fixed?
  • 22 Replies
  • 8364 Views
  • 7 In Conversation
Hakob
Can someone tell me if the local recording issue was fixed? I still have that problem.
22 REPLIES 22
Hakob,
To utilize local storage, see here: https://kb.arlo.com/1146857/How-do-I-set-up-local-storage-backups-on-a-USB-device-using-my-Arlo-base...
To set up direct access to local storage, for viewing remotely, see here: https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
garou5016
I can't record locally, either.  I'm on the current firmware and tried all of the troubleshooting procedures mentioned in the other threads about this issue.
ArloUser79
Garbage just garbage
Hakob
Whoever has an issue with recording can try this methods
Hakob
@JamesC ,
starting April 7th I again have a problem with local recording. I can not see the recorded videos. Is there problem again like we had end of last year ?
thanks
Hakob
fifoome
Same here, it was working before, it broke once last year, and now again:
- camera recording on the base station (I can see the files when look directly into the microSD
- I receive IOS notification on my phone
- no events in the feeds of any type
Has Arlo broken once again the local recording and just don't care about communicating / fixing it because it doesn't involve us paying for subscriptions?
it has now been months this feature has been broken and can't be trusted.
And yet Arlo doesn't seem to understand that the security and live of people are linked to this security system?
@JamesCcan we get an ETA on a fix?
Hakob
I have the same exact issue and I had end of last year as well.
The dev team is currently investigating reports of this issue. I will provide an update as soon as we have more information.
Hakob
@JamesC
Thanks James.
Hakob
@JamesC
is there any updates?
thanks
Hakob
Hakob
@JamesC
Do you have any updates when this issue will be resolved?
Hakob
Hakob,
The development team is still working on fixes for some issues related to local storage. Some adjustments have already been made and there have been reports from some users that factory resetting and re-adding the base station, resyncing cameras and setting up local storage again has resolved the issue.
Hakob
@JamesC
I reset the devices but issue wasn’t resolved. I hope the development team will fix the issue quickly.
thanks
Hakob
The development team is currently testing a fix for this issue. I will provide an update as soon as I have more information available to share.
fifoome
Any ETA / Updates on that fix?
Hakob
@JamesC , do you have any update?
thanks
Hakob
gto88
Just learned that Ultra 2 need subscription to record on cloud, if no subscription and using local storage, it will record locally, but cannot be viewed in app, one must pull out the sd card and use pc to view it????
I am out of return window, so Arlo reject my return because of this nonsense use model.
I have 4 other Arlo camera work perfectly with local recording, and this new Ultra 2 will
not allow to view recording in app, unless add subscription,  how do you put this, I thought I own the camera don't I, then how come I need to pat extra to see the full function of it??
An worse scenario is, the hidden recording cannot be deleted from app will overwrite my other
recordings when it is full and you will have to manually format it or move it to pc to clean up.
It induces a lot of work to maintain it.
This makes the Ultra 2 useless to me.
No.  If you have a VMB5000 smarthub (the only one that accepts a microsd card), then you can see local recordings in the app.
There are limitations:
  • Recordings can only be viewed from the primary account (not friend accounts)
  • Recordings can only be viewed from the phone app (not my.arlo.com)
  • No ability to make manual recordings or take snapshots
  • No thumbnails - all videos need to be downloaded to the phone to view
  • remote access requires router setting changes that some find difficult (and which don't work with some internet service providers).
Although many do use this instead of a subscription, I don't think it offers a good experience myself - IMO it is better suited for backup.
gto88
This is incorrect,
I have vmb4000, and it can have micro sd card as I am using it for all cameras
I have, and it doesn’t work for ultra 2 only.
according to Arlo support, it records in sd card, but it can only be viewed by move the sd card to pc.
This is not acceptable as an end user, and I will not buy any of such camera with limitation
not to say buying any new smart hub with limitation at all.
The VMB4000 accepts USB storage, and has no microSD slot.  If yours does have this slot (which is on the bottom of the smarthub, not the back), then you must have the VMB5000.  Look for a VMBxxxx label on the base to confirm the model.
The VMB4000 doesn't support direct access to local storage, the VMB5000 and VMB4540 do.  With the VMB4000, you do need to eject the local storage and connect it to a PC for viewing.
Legacy cameras (Pro, Pro 2, etc) were sold with 7 days of cloud storage, which Arlo still provides.  Currently sold cameras (including the Ultra 2) are not sold with that feature and require a subscription to get any cloud storage.
Many users find this confusing, and are thinking they are seeing local recordings for their legacy cameras in the app, when they are actually seeing cloud recordings.
It's easy to tell if they are in the cloud - just eject the storage.  If you can still see the recordings, then they are in the Arlo cloud.
gto88
Hi,
you are right, I checked and I realized that I use micro sd adapter for the usb port.
in any case, it is still very inconvenient for old vmb4000 smart hub users with newer camera.
thanks for clarify this.
totally agree.
  • 22 Replies
  • 8365 Views
  • 7 In Conversation
