Hi
I've had Ring cameras for several years, their har a far better user interface than the Arlo app, but then again,,,not any high def cameras.
I am used to when i view the cameras live, the stream is saved as "live view" on the Ring system, is ther any way to do this om the Arlo app?
I am also having trouble with saving snapshots form the Arlo app on Ultra 2 when i am on my phone iPhone 12, works fine on the Arlo Doorbell! When i am logged on to my computer the bar with snapshot appears
When you start livestreaming, you should be seeing both a recording icon and a snaphot icon on the video. Just touch them.
Note that
- you need to turn off local 4K streaming if you want these controls.
- you also need a subscription
Hi, thanks for replying.
1. Local streaming is off
2. I have an Arlo subscription covering all cameras
Took a snapshot of the line in the bottom
The record button only occasionally appears?
@zzotzx wrote:1. Local streaming is off
It should appear whenever you are livestreaming the camera.
Arlo Ultra 2
Prima di acquistare
