  • 8 Replies
  • 2377 Views
  • 3 Likes
halatacus01
Prior to the 4.3 update I had 2 alro ultra cameras and 3 chimes (1 x chime v1 connected to base station, and 2 x chime v2 connected to wifi) which were all set to play a traditional doorbell sound whenever motion was detected on either camera.
I bought an extra 2 Arlo Pro 5 cameras and when I added them my UI changes in the App to the new version. Now my chimes no longer work properly.  the only one that is accessible is the v1 chime connected to the base by the 2 Pro 5 cameras,  The Arlo Ultras cannot access or trigger the chimes. I tried removing and adding back the devices with no luck and under new routines section there is an option to play a sound but only shows 1 v1 chime, I want to add all 3.
The whole system has been working fine until the update and adding the new cameras.  Now I am having the base station dropping connection and the chimes not functioning properly
Please Help
Arlo Chime Arlo Chime 2 Arlo Ultra 2 Wireless Security Camera Arlo Pro 5S 2K
8 REPLIES 8
halatacus01
Can anyone help with this?
thanks
halatacus01
Is it possible someone from Arlo could respond to this.  I currently cannot get my two chime v2 to connect to the arlo cameras after the latest update.
thanks
halatcus01,
This is currently a limitation of the new user experience associated with the app update.
The development team is working on a solution for this. Stay tuned for an update.
halatacus01
Thanks for the reply JamesC,
Good to know this bug is being fixed as I have 2 new doorbells that cannot be used.
Also since the update there is a limit on what routines can be set to only 2 and off, this greatly reduces the previous functionality and would be good to reintroduce the ability to add more routines again.
Overall the update seems several steps backwards
Peter
halatacus01
James,
Any news when this will be fixed?  Seen there was an update a couple of days ago but still the chime 2s do not connect to the cameras?
I don't have any new information available at this time. Stay tuned for updates.
MileHighATLien
I am having a basically the same issue.  To Arlo: this really is quite a CRITICAL item, as having the Chime play is really the only way of receiving notification when (for example) you are asleep when the alarm is triggered, and the actual device is far away such that you cannot hear its siren.  Any updates/ estimates for a resolution?
halatacus01
Hi James,
There has been another software update from arlo, and yet still the functionality has not been restored.  Do you think it's acceptable that the update broke the use of the chime 2 with the cameras, rendering them USELESS and has still not been fixed?  It has left our property unsecure for weeks.  It is appauling that the update from arlo was rolled out and not properly tested.
Also as a community manager it would be helpful if you DID have some news on resolving this serious issue.
  • 8 Replies
  • 2378 Views
  • 3 Likes
