Are any of the current (non-EOL) systems as EASY to use/set up as the Pro/Pro2 system? We are not tech savvy. We only use our desktop for Arlo system and will NEVER be using our phones. I do not see base stations in the new bundles. We need 5 or 6 cameras and have no use for a doorbell camera unless we mount it to a deck railing to act only as a camera.
Any guidance would be helpful.
Thanks!
I should say we do have the 30 day subscription also.
Personally, I find that the new cameras are as easy to use as the old ones. The same web client does the same things. Other than the need for a subscription for the new cameras, there's no difference in usage.
Arlo Ultra 2
Prima di acquistare
