VMB5000r6 Arlo base station is not recording motions on my local SD card
1.24.0.1_1607_8938370
HardwareVMB5000r6
My Arlo base station is not recording motions on my local SD card. it was working fine up until last May 2024. there are no recordings in my library either.
Cloud recordings require a subscription - do you have one? Use live view and make a manual recording.
Since you're not getting local recordings, check the active mode to verify it has an appropriate rule for the camera. Rebooting the hub may work. Try using the Armed mode to see if that works.
Arlo Ultra 2
Prima di acquistare
