Arlo Ultra 2 False Motion Triggering
I have a newish Arlo ultra 2 that all the sudden has started triggering constant false motion alerts. There is nothing there. I brought the stupid thing inside to charge it and it's currently triggering false motion alerts while being pointed at a wall in a room by itself.
Is there any fix to this or did I waste my money on this piece of garbage?
Thanks in advance for replies.
I'd start by removing/reinserting the battery to reboot the camera.
If that doesn't help, then I'd do a hardware reset:
- Remove the camera from the account.
- Open the housing and press the button inside until the LED flashes amber (about 15 seconds)
- Add the camera back to the account.
I ended up sending it back. It just glitched out and that was it.
Arlo Ultra 2
Prima di acquistare
