VMB5000, Ultra 2 endless Audio notifications due to wind
  • 1 Reply
  • 968 Views
BrittanySpaniel
Looking for solutions to stop notifications from blowing up my phone during windy days. I’ve tried turning off cameras microphones and turning off smart notifications. There are currently no software updates for my system as well.
Help!
You have to disable audio notifications in the camera rule.
But disabling audio triggering likely isn't enough - wind often triggers the motion detection too.
Turning off smart notifications isn't the right solution, as it results in you getting all the notifications.  If you want to filter the notifications, you need to enable the feature.  Then turn off audio, and "all other motion".  That should reduce the flood of notifications, but won't reduce the recordings.
  • 1 Reply
  • 969 Views
