Did you check out the options for remote viewing of local recordings? Go to your hub settings and then to Storage Settings for using a VPN or port forwarding. It's been there all along.
@cloudwinked wrote:
Given your systems are not the cheapest, and given that you also OFFER the option of storing videos locally, you really ought to consider providing better advice on remote access options.
This is a user-to-user forum. Neither @jguerdat nor I work for Arlo - so NOT our systems.
FWIW, I do think Arlo should have implemented a better and seemless solution for this.
@cloudwinked wrote:
Yes, but being a gen-x’er, I don’t have the know how or knowledge of systems to understand what either involves without doing quite a bit more reading.
Port forwarding in your router isn't all that difficult. If you provide your router manufacturer and model, I can see if I can find a manual and point you to the right section.
FWIW, I'm a boomer, so I don't view being Gen-X as much of an excuse.
Arlo Ultra 2
Prima di acquistare
