2-step keeps denying push login to mobile device from browser.
2-step keeps denying login pushes to my cell phone. It is really annoying, only allows me to use email to verify. And since it deletes browsers every 14 days it is obnoxious. Why can I not disable 2 step. It is a camera system it is my choice. Fix your 2 step issues. BTW your chat system sucks and cannot even get ahold of anyone.
Yes everyone knows the bot sucks, that’s why they’re here.
You can access arlo support via the app settings, support page to open a fault case or speak to them if the options allow.
That's great so no help. If they can't make it work should be disabled. I am not paying to have more hassle than useful features.
Not everyone is experiencing the issue which makes it hard to find but the more customers complaining may help to isolate say a regional server issue.
If I could get to an actual person I would. They want to up the yearly cost now to a monthly cost. So now I am paying for security that hinders my own ability to see my own cameras because people make stupid passwords. I should be able to disable it, I pay for it. If they want to charge a monthly fee I should not have to work so hard to contact someone about something they should be troubleshooting as it has been over 4 months.
If you’re paying a subscription then you should have access to a phone number to contact them. If not then look at using the app to access under settings/support.
Arlo Ultra 2
Prima di acquistare
