I really appreciate the low battery alert. Would it be easy to add a fully charged alert to remind me to take the camera off the charger and put it back in place? I’m kinda forgetful and it would be really good for me. Anyone else agree?
That's what the LED notification setting in the camera settings is for. The LED will turn on blue when fully charged. Not the same as a notification, though. You might also consider the external charger and a second battery so you simply swap batteries and charge the depleted one offline.
Good work arounds thanks. But I'm disorganised and lazy. Still, the second battery and charger sounds like a plan!
Arlo Ultra 2
Prima di acquistare
