Hi All,
I have been recommended to Arlo but I am not a big fan on battery operated options even if the battery last months.
I am building a house and I have already run power over ethernet cables to the locations where my cameras will be located. Does this model or any of the other models have POE functionality?
Thanks,
Dylan
Best answers
Only the Q Plus has PoE capabilities. All the others use USB power.
None of the outdoor cameras have PoE. There is an older indoor camera (Arlo Q Plus) that did, but I don't think that is in production anymore.
Do you have a link to the Q plus? I dont see it on the site.
I need outdoor cameras with POE
Do you think its ok to have them perm plugged into AC?
Yes. You can do that either with the battery inserted or without the battery. I have a Pro 3 that's been running on AC for a few years now (with battery in my case).
Arlo Ultra 2
Prima di acquistare
