New set up. Camera works in the arlo app. Connected it to google home following the instructions. The camera shows as idle when it is on the split screen with other cameras and idle when it is pulled up full screen. I tried it "armed" and "Unarmed" with no change. Thank you!
I figured this out. I logged out of all the apps. Logged in to Arlo from a browser. Then went back to google home and it was live. Not sure why that combination worked. So far so good.
Google home makes you sign into arlo as you add the camera... No luck. Thank you.
Arlo Ultra 2
Prima di acquistare
