  • 2290 Views
bishoppl
New set up. Camera works in the arlo app. Connected it to google home following the instructions. The camera shows as idle when it is on the split screen with other cameras and idle when it is pulled up full screen. I tried it "armed" and "Unarmed" with no change. Thank you!
bishoppl
I figured this out. I logged out of all the apps. Logged in to Arlo from a browser. Then went back to google home and it was live. Not sure why that combination worked. So far so good.
JTorres1
I had them same issue, I was trouble shooting thecamera options/settings and was ready to give up! I believe what solved the issue was signing out from Arlo and the adding/linking the cameras back onto google home. Hope that helps you!
bishoppl
Google home makes you sign into arlo as you add the camera... No luck. Thank you.
bishoppl
  • 2291 Views
