Ultra 2 camera stops connecting to Smart Hub. Rebooting Hub works- for a while.
Although my Ultra Smart Hub LED shows blue, my Arlo Ultra 2 camera stops connecting. As soon as I unplug and reboot the Ultra Smart Hub, the camera immediately connects fine. It will stay connected for some days, then stops connecting. Wifi shows 3 bars and the hub is on an extension cord, so not near my wifi router. Any thoughts?
Have you tried to do a reset on the smart hub and add the camera back on to see if that helps with the behavior you are seeing?
That is something I recently tried. I uninstalled and unplugged the smart hub, then reinstalled it and then reinstalled the camera. That was about a week ago. Too early to tell if that is helping.
Please keep me updated if it resolved what you were seeing thank you.
Arlo Ultra 2
Prima di acquistare
