Ultra 2 Smart Plan, SD Questions and resolution question
  • 2377 Views
Allen012
Hi!  Just a few Ultra2 questions:
1.  Has anyone had the Pro3 and the Ultra2 and have any feedback for comparison?  I currently have the Pro3 and just bought the Costco 4 pack Ultra2 as a replacement.
2.  Is there a way to manipulate the Ultra2 settings and record in 1080, 2K or 4K?
3.  Can I purchase the 2K plan and record in 2K w/the Ultra2?
4.  Can I choose the resolution of the Ultra (2k or 4k)  when recording to the SD card in the HUB?
5.  Can I choose to record to the SD card in the HUB and record to the cloud?  Thanks!
pwaggs
SD card records whatever is being recorded in the cloud. It cannot record at a different spec than the cloud setting is set to record to.
1) I don't have an Ultra 2 so can't compare but I believe that the main differences are 2k vs. 4k and the Ultra 2 being able to be further from a hub. See https://kb.arlo.com/1088443/Which-Arlo-camera-is-right-for-me
2) I would assume it's the same as the Ultra so very likely.
3) Yes.
4) No.
5) A subscription will record to both the hub and cloud. Without a sub it will only record locally.
Allen012
Thanks for those answers, much appreciated!  As for the Pro3, a few more differences I found are the Ultra2 has dual microphones and dual motion sensors vs single for the pro3.  The Ultra2 also has "wind noise cancellation".  My Pro3 gets a ton of wind noise that's always setting off the alerts if I have "noise" selected as an alert function so I'm hoping to see some serious improvement with the new cameras.
  • 2378 Views
